1993 Ford Probe Squealing Belt
MTPOOLE
we have a 1993 ford probe automatic 4 cyclinder with 145000. It recently started making a squealing noise when you first start it and also when you turn the air conditioner on. It will go away when you drive but comes back when you come to a stop. We have replaced the ac belt and alternator belt and have tightened the ac belt.
Oct 28, 2007 at 7:34 AM
  • 75,988 POSTS
Recheck all belt tension-its still loose or use a belt tensioner to adjust.
Oct 29, 2007 at 1:52 PM
Suggested Repair
Recheck tension on all belts, as one may still be loose, and use a belt tensioner to adjust it properly.
Conversation Summary
The owner of a 1993 Ford Probe reports squealing at startup and when the air conditioner is turned on. The noise stops while driving and returns at a stop. The AC and alternator belts were replaced and the AC belt was tightened. The expert advises rechecking all belt tension and using a belt tensioner to adjust it.
