Scraping in brakes or tires
ONEINSANEMARINE
I have a 1995 ford probe and i just changed the brake pads in the front...it sounds like its scraping like ehwne the brakes need to be changed. im not sure if i screwed up the brakes or not. ive done it a few times before but never had any problems. maybe i need new rotors? the alignment is really bad too...maybe thats why? please help me..it sounds horrible!
May 25, 2007 at 3:52 PM
  • 75,988 POSTS
[quote:e0fc0f99ac="oneinsanemarine"]I have a 1995 ford probe and i just changed the brake pads in the front...it sounds like its scraping like ehwne the brakes need to be changed. im not sure if i screwed up the brakes or not. ive done it a few times before but never had any problems. maybe i need new rotors? the alignment is really bad too...maybe thats why? please help me..it sounds horrible![/quote:e0fc0f99ac]
SCRAPING NOISE FROM BRAKES Usually indicates metal-to-metal contact and the need for a long overdue brake job. Drum and rotor resurfacing will likely be needed in addition to new linings and brake hardware.
Get the alignment fix
May 25, 2007 at 5:44 PM
