OVERHEATING
SPARKY87
  • FORD PROBE
My 1995 Ford Probe SE, 4 cyl. 2 liter, will overheat just driving it around the block. I just replaced the water pump and it’s working. I replaced all the hoses, the thermostat and flushed out the radiator. Water seems 2 flow through every thing when it’s not put together, but if I put every thing together and start it, I can't get 300 yards with out it overheating. Help Please!
Monday, March 12th, 2007 AT 11:51 PM
CHEVY22
  • 1,375 POSTS
Are the fans coming on at operating temps, and is your gage reading hot or the gage and the engine hot
Jim
Tuesday, March 13th, 2007 AT 2:18 PM
SPARKY87
The fan is turning on and the gage in the car is reading hot
Tuesday, March 13th, 2007 AT 6:40 PM
CHEVY22
  • 1,375 POSTS
Is the engine hot, the radiator? Gage could be wrong
Tuesday, March 13th, 2007 AT 6:42 PM
GEEE
Did you havethis same problem before you replaced the pump. I have hjad new pumps on this type of vehical that the impeller was loose on the shaft
Tuesday, March 13th, 2007 AT 6:55 PM
SPARKY87
No the problem just started. So I took the water pump back out and its good. I herd that I mite have a air bubble in the bock. Can this happen? And how do I get it out.
Tuesday, March 13th, 2007 AT 7:32 PM
SPARKY87
The radiator is warm and the engain is really hot
Tuesday, March 13th, 2007 AT 7:33 PM
