1997 Ford Probe Injector Ticking Noise Fix
MILNER142790
my '97 probe has a loud ticking noise from by the injectors when it is at running tempreture, is there anything i can do to fix this problem?
Mar 12, 2006 at 6:28 AM
RAYHUT
  • 134 POSTS
the ticking noise likely means you need to replace your injectors.
Mar 12, 2006 at 8:49 PM
Suggested Repair
Replace the fuel injectors. The loud ticking near the injectors at operating temperature was attributed to injectors that need replacement.
Conversation Summary
The owner of a 1997 Ford Probe 2.0L reported a loud ticking noise near the injectors once the engine reached operating temperature and asked how to fix it. The expert said the noise means the fuel injectors should be replaced.
