FORD PROBE 95
JAMIEBEAU
I JUST BOUGHT A 95 FORD PROBE AND I WAS DRIVING IT HOME AND I TURNED AROUND A CORNER AND IT DIED WELL I GOT A JUMP AND IT STARTED FOR A BRIEF MINUTE AND DIED AGAIN WELL THE ENGINE WILL TURN BUT I DONT HAVE A SPARK IT IS A 95 FORD PROBE 4 CYLYNDER 16VALVE WITH ABOUT 110000 MILES
Mar 2, 2007 at 1:29 PM
BHUGG
  • 157 POSTS
If there is not spark, start checking the fuses. there is a fuse panel under the hood that has ignition and engine circuit fuses and some relays that could be bad. Check these out. Also check the fuses in the dash. If all the fuses are good, try to switch some of the relays around (make sure they are the same) to see if it is a problem there.
If we help, let us know.
The forum is here to help and we want to know if we are helping.
Give us a vote if we deserve it.
Mar 3, 2007 at 5:33 PM
