1997 Ford Probe Oil Consumption
MARK ELLISS
i have a ford probe 2.0L 1997, 75,000 with excessive oil consumption approx 300 miles to a litre of oil
stem seals replaced but no improvement and appears to be marginally worse regularly serviced. Can you help?
Oct 8, 2007 at 7:08 AM
MERLIN2021
  • 17,250 POSTS
Before you replaced the stem seals, did you do a compression test? at this point it would seem that the rings are the problem! and at 300 miles per litre of oil...thats what? almost a gallon? This car could be used as a smokescreen for the RAF!
Oct 8, 2007 at 8:51 AM
Suggested Repair
Perform a compression test to check for worn piston rings. Valve stem seals were already replaced with no improvement, so low compression would point to ring wear as the cause of the oil consumption.
Conversation Summary
A 1997 Ford Probe 2.0L with 75,000 miles uses about one litre of oil every 300 miles. Valve stem seals were replaced and the car is regularly serviced, but consumption did not improve and may be slightly worse. The expert asked whether a compression test was done before the seals were replaced and indicated worn piston rings are the likely cause.
