Ford Probe Cuts Out When Cold
WOODY31
my ford probe 2l 16v 73455 it cuts out when it is cold but does not do it when its warm it can cut out a few times before it works
Nov 25, 2006 at 3:54 AM
CATCH_15
  • 250 POSTS
Has the car had routine maintenence performed? If not, that could be your problem. New plugs, wires, distributor cap, air filter are all a part of a tune up that should be performed on a car as it approaches 80-90,000 miles.
Nov 26, 2006 at 3:07 PM
Suggested Repair
Perform a tune-up with new spark plugs, plug wires, distributor cap, and air filter, especially as mileage approaches 80,000–90,000 miles.
Conversation Summary
The owner of a Ford Probe 2.0L 16-valve with about 73,455 miles says it cuts out when cold, sometimes several times, but runs normally once warm. The expert asks whether routine maintenance has been done and recommends a tune-up including plugs, wires, distributor cap, and air filter.
