car won't stay running
ROBNSAB
  • 5 POSTS
I HAVE A 94 PROBE GT WITH 114000 MILES ON IT. A COUPLE OF WEEKS AGO IT QUIT RUNNING AND WOULD NOT START AGAIN. I HAD NO SPARK, SO I CHANGED THE DISTRIBUTOR AFTER TESTING IT. WITH THE NEW DISTRIBUTOR THE CAR WILL START AND RUN FOR ABOUNT 20 MIN THEN DIE. WHEN YOU CRANK THE ENGINE AFTER IT DIES I GET NO SPARK BUT IF IWAIT FOR AT LEAST 30 MIN THE CARWILL START AGAIN AND RUN ANOTHER 20 MIN REPEATING THE PROCESS. I CHANGED THE PLUGS, WIRES, CAP, ROTOR, AND CRANKSHAFT POSITION SENSOR SO FAR. WHEN IT DIES IT DOESN'T SAVE A FAULT CODE. IN NEED OF ANY IDEAS. DO YOU THINK THE NEW DISTIBUTOR IS BAD ??????
May 6, 2006 at 11:45 AM
ROBNSAB
  • 5 POSTS
the distributor was bad. put new won in and car runs great. i ran it for over 3 hours today just to test it out. i think i fried the other distributor when i ran it with the bad spark plug wires (at the time i did not know they were bad). i think i burned out the resistor in it so when it got hot it quit working.
May 11, 2006 at 2:00 PM
