HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Probe
Warning Lights
Low Fuel Light
93 Ford Probe gt
JUAN CARLOS
MEMBER
1993 FORD PROBE
What does it mean when the fuel cutout light comes on
Monday, May 8th, 2006 AT 5:40 PM
LOSONE
MECHANIC
It means that the fuel cutoff switch is of cutting off power to the fuel pump or you have less than 1 gallon of gas. Is the car running?
SPONSORED LINKS
Monday, May 8th, 2006 AT 6:17 PM
Please
login
or
register
to post a reply.
Related Low Fuel Light Content
1993 Ford Probe Fuel Cut Light On Dash
My Fuel Light Cut Off On Dash Is On Now Car Wont Start Now It Cranks Over But Wont Start Where Is Cut Off Switch?
Asked by
carlkpe
1 ANSWER
1993
FORD PROBE
1994 Ford Probe Fuel Cutoff Light On, Can Hear Pump...
Car Sat Idle For Over 2 Years. Car Started Twice Just Prior To Repair Work. Replaced Timing Belt, Water Pump, Fuel And Air Filters And...
Asked by
wnaigle
1994
FORD PROBE
1994 Ford Probe Fuel Cutout Light
The Engine Starts And Runs Fine, But The Fuel Cutout Light Is On And Stays On. Can Not Find The Reason Why The Light Will Not Go Out. I...
Asked by
shadow246
1 ANSWER
1994
FORD PROBE
Fuel Cutoff Light Came On While Driving.. But Still...
I Have Gotten Gas Then I Was Turning Onto Another Road This Morning When The Fuel Cut Off Light Came On And Then Shortly After The Check...
Asked by
Batavias
1 ANSWER
4 IMAGES
1994
FORD PROBE
Fuel Cutout Light
My Ford Probe Gt Is A 93 Model With 153,000 Miles On It. Recently I Had To Change The Transmission And It Hasnt Been Running Right Since...
Asked by
Blake1705
1 ANSWER
FORD PROBE
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Mercedes-Benz C230
Check Engine Light Safe to Drive?
Oil Life Reset Toyota Camry
Online car repair manuals
