The engine starts and runs fine, but the fuel cutout light is on and stays on. Can not find the reason why the light will not go out. I checked the inertia switch and it is fine. When I unplug it the engine will stop running. The wiring in at the switch is in good condition. I had a new transmission installed. Don"t think that would have anything to do with it. I have pulled out the dash and found no problems there. I have also checked the connection under the car just behind the fuel tank. Thought there might be a short, but again found no problems.
Hope you can help. I"ve ask other mechanics and had no luck.
thank You
thank You
Aug 30, 2010 at 9:24 AM
