92 ford Probe Idling and stalling
CHRSYAL
I have a 1992 Ford Probe with 117,000 miles on the vehicle. When I drive for about an hour to two hours the car will stall and I can pull over and let the car sit for 10 minutes to a 1/2 hour and the car will start up and drive for another hour. what can i do to fix this? Also after the car warms up the car idles high than low high than low every time I slow the car down and stop. As if it wants to stall. But the car does not stall. How can I fix this problem?
Jan 18, 2006 at 1:37 AM
J41LA
does your "check engine" light come on?
Jan 18, 2006 at 3:11 AM
CHRSYAL
yes my check engine light is always on, i had just recently fixed all leaky hoses and changed the spark plugs, and the thermostat. as well as flushed out the radiator system. check engine light went off for a couple of days than it came back on.
Jan 20, 2006 at 1:41 AM
