1997 Ford Probe engine doesn't seem to fire
1997 FORD PROBE
120,000 MILES • 4 CYL • FWD • AUTOMATIC
LILMAMALINDA2007
tis car has had alot of new parts and work done on it since I've had it. I recently had the head gasket replaced. The car makes a whizzing sound when the key is turned over and won't start. Thought it was the coil so had replaced. Still doesn't start.
Apr 2, 2010 at 4:43 AM
LEGITIMATE007
  • 5,121 POSTS
sounds like the starter, isnt seated to the flywheel correctly. or the flywheel has chipped teeth
Apr 4, 2010 at 6:18 AM
