1997 Ford Probe a miss in engine
117,000 MILES • 6 CYL • FWD • AUTOMATIC
DALTON.JOHN43
i recently pulled a plug wire off and since then i developed a miss in the engine I changed the plugs and wires and the miss didnt go away what could be the cause?
Oct 9, 2009 at 7:45 AM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Oct 9, 2009 at 10:26 AM
