1996 Ford Probe very low idle and sputtering
1996 FORD PROBE
47,996 MILES • 6 CYL • FWD • AUTOMATIC
AMPBASSIST
i drive a 96 ford probe gt 24valve 6 cylinder non turbo and my check engine light came one. i replaced all wires plugs, left and right gasket covers and head gasket. it fixed the check engine light problem for a while but recently when im idle my car will shake like its struggling and idles at 500 rpm and starts flashing the check engine light. however when driving the problem does not exist. i have tried idling and giving enough gas to wear it idles at 1000 rpm and the car sits fine. its only when im completely idle does the car shake and the check engine light starts flashing.
help is much needed =[
Sep 13, 2010 at 1:33 PM
WRENCHTECH
  • 20,761 POSTS
If the check engine light is flashing, you have a severe misfire condition and you need to have the codes read to identify the cylinder.
Sep 13, 2010 at 1:52 PM
AMPBASSIST
already had it checked, it labels as random cylinder misfire
Sep 13, 2010 at 2:43 PM
