1996 Ford Probe transmission filter change
1996 FORD PROBE
NORMATMETLPANELS
Transmission problem
1996 Ford Probe 4 cyl Two Wheel Drive Automatic
orielly parts screen cautions that transmission dissasembly is required to change filter, what does that mean
Aug 23, 2008 at 1:32 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:f415c80357="normatmetlpanels"]Transmission problem
orielly parts screen cautions that transmission dissasembly is required to change filter, what does that mean[/quote:f415c80357]
Don't honestly know what they mean....
To change the fluid and filter just remove the tranny pan carefull will fluid then remove filter and replace. That should be it.
Aug 23, 2008 at 4:16 PM
