1996 Ford Probe squeaky belt
208,000 MILES • 6 CYL • FWD • MANUAL
CWADSWORTH
How do you fix a squeaky belt?
It squeaks when I turn on the A/C or heat.
Can the belt be tightened?
Thanks,
Craig
Dec 28, 2007 at 9:53 AM
  • 31,937 POSTS
Hi there,
Individual belt systems, will have adjusters for each belt, single belt systems (serpentine belts) have an automatic pretensioner, First inspect the belt for damage before adjusting. Most a/c systems use a adjustable idler pulley. back off the pulley centre bolt, tighten with adjuster bolt, this will move the pulley, and tighten the centre bolt again.
Mark (mhpautos)
Dec 28, 2007 at 11:14 AM
