One day the car just stopped. I took it to a local garage and they put it on the coputer to test it. It said the plug on the aircleaner was bad they replaced it still nothing. Next they tested the fuel pump and the relay in the trunk area. They were fine, the fuel pump read 42 lbs pressure. Next they checked the timing and that was fine then they hooked up a fuel bottle up front and the motor ran so they tested some more and said it was the dist. It was replaced with a new one still nothing. The next thing I did was contact a ford mechanic and he said with all that was done it was the PCM coputer. I was looking around and see there is a Ecm comp. and I was wondering what is what with these ECM and PCM also will they fit from the same years or what is the best way to get a used on and be sure it is the right one
Aug 4, 2010 at 8:12 AM
