Engine Mechanical problem
1996 Ford Probe 6 cyl Front Wheel Drive Manual 130k miles
i cant get spark in my 96 probe gt. ive replaced the dist. spark plugs and wires as well as the crankshaft sensor. i was told it was a short in the wire tot he crankshaft sensor or the connector. it turns over and the fuel injectors will kick on it just wont get any spark. i talked to a ford specialist and it has compression and the timing belt is working properly
Mar 7, 2010 at 9:47 AM
