1996 Ford Probe my car will not start
THERESAKARESA
Engine Mechanical problem
1996 Ford Probe Two Wheel Drive Automatic 154751 miles
When i got my car the gas was empty. so i took it to fill the tank and took it home i let it sit over night and in the morring it would not start it was cool that night but it wouldnt start later in the day to.
Feb 22, 2009 at 7:50 AM
  • 110,251 POSTS
Hi:
I need you to check for two things. First check to see if you are getting spark to the plugs and fuel to the engine. One will be missing and I have a feeling it is the fuel. If the tank was empty, the pump may have picked up dirt and plugged the fuel filter, or damaged the pump itself.
Here is a video "How To" for checking fuel pressure. Many parts stores will lend or rent the gauge to you.
Check it out.
https://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know what you find and we'll move on from there.
Feb 22, 2009 at 12:04 PM
