1996 Ford Probe keeps blowing dist. 2 used 2 new
1996 FORD PROBE
125,000 MILES • 6 CYL • FWD • AUTOMATIC
PJCHAFF
found out that motor was changed prior to purchase.
no problems 4 first year , then intermitent no spark,
wen weather was cold {michigan} but would start.
later in day & be fine 4 a while. dist. finaly died .replaced w/used was fine 4 about 250 miles. & then went out agian. both times when first started.
that day.went through wiring harnes seems ok have 12 volts at dist plug. replaced w/new dist ran ok intil at operating temp 4 afew miles then would start to miss,
first new dist lasted 3 days,aprox 25 miles . company replaced, & 2nd new dist lasted 2 weeks aprox 80 miles
were can i look? what should reading at dist plug #2
circut 702 PCM power relay input?
Apr 8, 2010 at 1:49 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Sorry no one has gotten to your question until now. I will help out the best I can. I am better with electrical hands on then trying to walk someone through.
So, I have a question or 2 for you...
First what lead you to determine that the Distributor was the problem?
Next when you had no spark did you check to see if you had Fuel pressure or that the fuel pump was kicking in?
I ask because the Fuel Inertia Switch could be the cause and not the distributor.
Another possible cause is the Crank Shaft Sensor.
Apr 14, 2010 at 8:55 AM
PJCHAFF
it is perplexing ,w/first new dist. went out going down the road, would start agian ,sputter & die like was out of gas , didnt have guage but had pleanty of presure at the rack. checked spark w/screwdriver weak yellow spark. spark eventualy quit, checking the 6 pin plug to dist. w/test light have good power at pin#2 PCM,but also have residual power (about half as brite) at
pin #4 ground signal (cylinder identification) circut
#742 is this normal?
Apr 15, 2010 at 12:19 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Here are a couple test to do on the Crank Shaft Position Sensor...
NOTE:
CIRCUIT PIN IDENTIFICATION
CIRCUIT TEST CKP2
Crankshaft Position Sensor NO. 2
NOTE:
2.5L has 2 crankshaft position sensors.
Circuit _________ Breakout Box Pin No. _________ PCM Pin_________ Wire Color
CKP1 ___________ 56 _________ 3E________ LightGreen/Orange
GND________ 49________3C _________Blk/Red
VPWR ______37 & 57_________1B________Red/Black
1) Check System Integrity Visually check all wiring, connectors and components for evidence of damage, shorting or looseness. If a fault is found, repair as necessary. If no fault is found, go to next step.
2) Check CKP1 Signal Turn ignition off. Install breakout box. Connect PCM to breakout box. Measure voltage at CKP1 test pin at breakout box while bumping starter. If voltage does not fluctuate between zero and 5 volts, go to next step. If voltage fluctuates between zero and 5 volts, CKP1 circuit is okay. If sent to this test by a specific code, replace PCM.
3) Check VPWR To Distributor Turn ignition off. Disconnect distributor connector. Turn ignition on. Measure voltage at distributor VPWR wire. If voltage is more than 10 volts, go to next step. If voltage is 10 volts or less, perform CIRCUIT TEST VPWR. If results of CIRCUIT TEST VPWR are okay, repair open in VPWR wire to distributor.
4) Check Distributor Ground Ensure ignition is off and distributor is disconnected. Measure resistance between distributor connector GND wire and ground. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair open in distributor GND wire.
5) Check For Open CKP1 Wire Ensure ignition is off and distributor is disconnected. With breakout box installed, disconnect PCM connectors. Measure resistance of CKP1 wire between CKP1 test pin at breakout box and CKP1 terminal at distributor connector. See Fig. 5 . If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair open CKP1 wire.
6) Check For Short In CKP1 Wire Ensure ignition is off and distributor is disconnected. With breakout box installed and PCM disconnected, measure resistance of CKP1 wire between ground and CKP1 test pin at breakout box. If resistance is more than 10,000 ohms, replace distributor. If resistance is 10,000 ohms or less, repair short to ground in CKP1 wire.
Enter this test only when Code 02 is displayed during self-test procedures (KOEO or KOER) or when directed here from another circuit test. This test is intended to diagnose CKP2 circuit only.
I will email the rest to you in an xps file.
Apr 15, 2010 at 1:17 PM
PJCHAFF
what is breakout box? & I only have 9.75 volts at dist,also have 5 volts at ground cylinder identifation, ground at dist is good
Apr 19, 2010 at 8:05 AM
OBXAUTOMEDIC
  • 3,711 POSTS
A breakout box is an expensive piece of diagnostic equipment. It connects between the PCM Harness and the PCM to make checking voltage and all easier and quicker.
Sorry, should have told you to just back probe the Pins on the PCM.
Apr 19, 2010 at 1:59 PM
