1996 Ford Probe help
115,000 MILES • 4 CYL • FWD • MANUAL
KAMI6336
Hi, I need help. I have gone over everything that I can think of. I have a 96 ford probe, with 115,000 and it sat for 15 months while I was in Iraq. Before I left, it would blow white smoke when accelerating. So I replaced the head gaskets. Did a tune up and found oil in where the spark plugs sit, and it won't go over 50 mph. What do you think it might be? Please HELP. thank you so much.... k
Nov 11, 2008 at 1:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Thank you for serving our country.
I hope I can help here.
It sounds like your piston rings or valve guides may be worn which is what is causing the oil on the plugs.
Oil on the plugs will decrease the amount of spark your vehicle is getting, thus reducing our engines performance tremendously.
Thanks for using 2carpros.com!
Nov 11, 2008 at 1:38 PM
KAMI6336
how do i get rid of it, and why is there oil in there????
Nov 11, 2008 at 1:40 PM
KAMI6336
so are piston rings a pain to change, or should i just look in to getting another engine? sorry about that last question about how it got there, i didn't read your full response first. i was just excited about getting an answer so quickly.. thank you so much.
Nov 11, 2008 at 1:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
[quote:1452cd01c8="kami6336"]how do i get rid of it, and why is there oil in there????[/quote:1452cd01c8]
If the piston rings or valve guides are worn, oil can slip through. You need to have both the piston rings and the valve guides inspected so you can replace whichever one has failed.
Until then it will continue to smoke and run poorly.
Nov 11, 2008 at 1:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
[quote:bb17bb82dc="kami6336"]so are piston rings a pain to change, or should i just look in to getting another engine? sorry about that last question about how it got there, i didn't read your full response first. i was just excited about getting an answer so quickly.. thank you so much.[/quote:bb17bb82dc]
They are quiet a job. If you are not experienced in mechanics I would suggest taking it to a repair shop. Have an estimate to see what it would cost. I certainly wouldn't think that you should buy a new engine over it though.
Nov 11, 2008 at 1:50 PM
