1996 Ford Probe Fuel Injectors
1996 FORD PROBE
89,000 MILES • 4 CYL • FWD • AUTOMATIC
ASCHEED
I am doing a mini over haul - replacing the head gasket,timing belt,water pump. I have put it back together but I am not getting any fuel to the cyclinders. The fuel rail is full and pressurized. I check the volts at the injectors I get 12v. But if I turn the engine over there is no pulse. I changed the crank sensor what else can I check?
Oct 20, 2010 at 6:33 AM
WRENCHTECH
  • 20,761 POSTS
That would be an issue with the PCM or related wiring. It would require extensive testing to be sure.
See if you have spark. If no spark either, possible crank sensor circuit issue.
Oct 20, 2010 at 7:23 AM
ASCHEED
I know the the PCN recieves a pluse from the crank sensor and the distributor. Is it possible that the timing is way off causing the PCN to shut down the injectors?
Oct 21, 2010 at 12:23 AM
WRENCHTECH
  • 20,761 POSTS
NO
Oct 21, 2010 at 12:24 AM
