1996 Ford Probe
LIL NANCY
Drive Train Axles Bearings problem
1996 Ford Probe 4 cyl Front Wheel Drive
how long does it take to put a c v joint on a car and where is it located at
Mar 10, 2010 at 8:59 AM
ENOCHAHORNE
  • 8 POSTS
on that probe you will be better of buying a whole drive axle.or you can just replace the bearings.but faster the other way.the drive axle is located on the front of the car.you will have to pull the front tire of,the brakes etc.you will proberly will need a puller.but you will see the drive going from the transmission to the wheel hub.the cv joint is inside the drive axle.a repair manual will help greatly.
Mar 10, 2010 at 9:14 AM
