1995 Ford Probe FORD PROBE CIFFICULT TO SELECT GEARS
130,000 MILES • 4 CYL • FWD • MANUAL
SELWYN MENTOR
HI,
I'M HAVING TROUBLE WITH MY CARS TRANSMITION.
AFTER I'VE DRIVEN IT FOR A FEW MILES THE GEARSHIFT,BECOMES STIFF,& HARD TO SELECT INTO GEARS,AS I'M DRIVING.ALSO THE CLUTCH PEDAL SEEMS TO BE QUITE SOFT WHEN I DEPRESS IT TO SELECT IT INTO GEAR.
KIND REGARDS.
SELWYN
Jul 25, 2010 at 10:10 PM
  • 75,988 POSTS
Check the transmission gear oil make sure its on full if okay check the clutch master cylinder if its full if okay bleed the clutch and see what happens if it continues you need a clutch assembly.
Jul 25, 2010 at 10:15 PM
