Rescently had idle problems, removed IAC and throttle body and cleaned, noticed the fan coming on when key is turned on at start up, Never has done this before at start up, only when warm does fan usually come on. replaced fan switch, no change. Checked fire to all plugs, checked fuel pump,ok . Seems like not getting fuel through injectors. Was wondering if this engine has cam shaft pos sensor built into distributor. What would cause this not to get fuel, could it be the computer,erg valve?
Mar 24, 2009 at 1:21 AM
