1995 Ford Probe Engine not starting
147,000 MILES • 4 CYL • FWD • MANUAL
HEATH1390
Rescently had idle problems, removed IAC and throttle body and cleaned, noticed the fan coming on when key is turned on at start up, Never has done this before at start up, only when warm does fan usually come on. replaced fan switch, no change. Checked fire to all plugs, checked fuel pump,ok . Seems like not getting fuel through injectors. Was wondering if this engine has cam shaft pos sensor built into distributor. What would cause this not to get fuel, could it be the computer,erg valve?
Mar 24, 2009 at 1:21 AM
DOCFIXIT
  • 18,828 POSTS
Crankshaft sensor is part of distributor. Maybe ICM located left strut tower
Mar 24, 2009 at 5:22 AM
