1995 Ford Probe ecu
JBR
Electrical problem
1995 Ford Probe 6 cyl Front Wheel Drive Manual 100k+ miles
I have done all the tests! Scanner says no signal from crankshaft sensor #2 Replaced sensor scanner says no signal cranshaft sensor #2 Did continuity test on wires from sensor to ecu show good. Checked voltage and resistance at ecu connecter,is good. Dont know how to test ecu or is replacement needed?
Jan 7, 2009 at 9:53 AM
MABBOTT
  • 8 POSTS
this sounds like the same thing going on with my car i have been working on this for about 9/10 months now have spent way to much money and still have not got anywhere my E - Mail address is AbbottM72@aol.com if you find anything would you please let me know. If you want to give me your E - mail address i will be sure to let you know if i find anything....Good Luck
Jan 8, 2009 at 3:05 PM
