1995 Ford Probe
1995 FORD PROBE
130,000 MILES • 6 CYL • FWD • MANUAL
STACEY STANLEY
The car uesd to run good until it warmed up. Then when I tured it off it would not start till it cooled off. I replace the distributor,cap,rotor,wire,fuel filter, fuel relay and fuel pump. Now it will not start. I am getting no power to the pump or spark to the plugs. I need advice?
Mar 12, 2010 at 9:59 AM
DOCFIXIT
  • 18,828 POSTS
Check EGI INJ fuse underhood box also see if PCM relay is clicking in start
Mar 12, 2010 at 11:18 AM
