1995 Ford Probe
COLLEEN AND RICK
Engine Performance problem
1995 Ford Probe Two Wheel Drive Automatic 98,000 miles
Once the car has warmed up, which does not take long in AZ. I can not get the car to accelerate over 35mph. I have had a tune up on the car. I have 4 new spark plugs, new plug wire set, Fuel filter, dist cap and rotor. Also earlier in the year I replace the catalytic converter. There was NOTHING left of the one that should have been then. (It might have melted due to the car only running off of 3 cylinders for, I don't know how long)But that has not helped. What else should I do?
Jun 25, 2008 at 4:59 AM
DOCFIXIT
  • 18,828 POSTS
First thing that comes to mind is the ign. coil and fuel pressure. Check these out
Jun 25, 2008 at 5:15 AM
