1995 Ford Probe
GHOSTRYDDER99
Engine Performance problem
1995 Ford Probe 6 cyl Front Wheel Drive Manual
My car is reading low fuel pressure on tests. I've replaced the fuel pump, spark plugs, wires, distributer cap and blade, fuel filter, and changed the M.A.S., yet I'm still having the same problem. Any suggestions?
Feb 24, 2009 at 6:39 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:15c11f2697="ghostrydder99@yahoo.com"]Engine Performance problem
My car is reading low fuel pressure on tests. I've replaced the fuel pump, spark plugs, wires, distributer cap and blade, fuel filter, and changed the M.A.S., yet I'm still having the same problem. Any suggestions?[/quote:15c11f2697]
Have you checked the Fuel Pressure Regulator.
check out the video .....
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Feb 24, 2009 at 6:46 AM
