1994 Ford Probe Will not turnover
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
CALVINW3
When I turn the key, I can hear some clicks but the starter does not engage and turnover the engine. I checked the fuses, replaced the battery, and replaced the starter. I have 12 volts at the starter motor but not at the solenoid.
Jan 31, 2010 at 5:02 AM
  • 75,988 POSTS
Check for power at the S teminal of the starter relay while disconnected, do you have it? If not test the neutral safety switch and ignition switch
Jan 31, 2010 at 5:06 AM
