1994 Ford Probe transmission slipping and leaking
1994 FORD PROBE
GLOWE
Transmission problem
1994 Ford Probe 4 cyl Automatic 125000 miles
Is there hope? Seems ok when cool and fluid kept being added. Where could the leak be coming from?
Motor mounts and transmission mount replaced about a week ago. What should I check next?
Sep 10, 2008 at 11:09 AM
  • 31,937 POSTS
Hi there,
the leak will be either the front shaft seal, the box has to be removed to replace this, or drive shaft seals or pan gasket, you should be able to locate this leaks easily, have a look and report back.
mark (mhpautos)
Sep 10, 2008 at 6:15 PM
