1994 Ford Probe transmission filter
1994 FORD PROBE
BESSTUP
Transmission problem
1994 Ford Probe Automatic
I need to know how to change the transmission filter in my car. I took the pan off of it which is on the side of the transmission, and I couldn't see the filter anywhere.
Dec 17, 2009 at 5:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if you removed oil pan from tranny then you should have seen the filter screen..you don't have to replace this filter screen, simply clean it is good enough. you do need to use new "O" rings though when reinstalling. filter and gasket set will look similar to pic below..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1356.jpg
Dec 28, 2009 at 5:00 PM
