1994 Ford Probe Rough Riding
FASTCAT003
Engine Mechanical problem
1994 Ford Probe 4 cyl Two Wheel Drive Automatic 196ths miles
My 1994 ford probe runs rough with a loss of power? What can i do to fix it to get back to smooth riding again?
Jun 1, 2010 at 6:39 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jun 4, 2010 at 4:17 PM
