1994 Ford Probe Ignition switch
150,000 MILES • 6 CYL • FWD • MANUAL
BOB B KING
key broke inside ignition switch. How do I get the broken part stuck inside out? If I have to dismantle the whole thing, can you show me how? Plus, is thi what is causing my battery to drain so fast?
Dec 25, 2009 at 1:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If a bit of the broken key is sticking out of the lock, grasp it firmly with needle-nose pliers and pull it out.
If the broken end of the key is visible but you can't grasp it with pliers, try the following superglue method.
Use a toothpick to apply a tiny amount of superglue to the broken edge of the key's head.
Insert the head into the lock so the broken edges of the key come together. Be extremely careful not to let the glue come into contact with any part of the lock.
Hold the key in place firmly for at least 3 minutes to allow the glue to dry and bond the broken pieces.
Carefully extract the key from the lock. Avoid unnecessary twisting or turning because this will strain the superglue bond.
Call a locksmith if you can't extract the key with either method. Locksmiths have a key-extractor tool designed specifically for this predicament.
Dec 28, 2009 at 4:55 PM
