1994 Ford Probe Gt
METAL_DISASTERPIECE
  • 5 POSTS
I have a 1994 Ford Probe GT equipped with the 2.5L 24 Valve DOHC V6. My Fuel Cutoff light stays on when the car is not running, when the car starts i have to constantly pump the gas or it will die, also the car will not rev up over 3000 rpm's. I just bout the car and got it running, i replaced the timing belt, cuz it had come off while the car was idleing, i replaced the fuel pump and the cutoff light is still on, ive tried pushing the fuel pump switch in the trunk in and out and still the same thing, do you know whats goin on with this car, i really need to get this thing goin its killing me having it just sit there. also the car will not even start when the air intake is connected to the throttle body.
May 10, 2007 at 6:12 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like you might have a Mass Airflow Meter problem. Any check engine light?
May 10, 2007 at 8:21 AM
METAL_DISASTERPIECE
  • 5 POSTS
[quote:2e5c0dae8a="2CarPro Jack"]Sounds like you might have a Mass Airflow Meter problem. Any check engine light?[/quote:2e5c0dae8a]
My check engine light is not on, im not sure why its not actually it may have been disabled i just bought the car, the guy told me it needed a new timing belt so i replaced it and here i am now with this problem,
The car wont idle high enough to stay goin and it wont rev up over 3000rpm with the mass airflow Disconnected, when it is connected it wont even start.
ive tried everything i can think of
Thank You
May 10, 2007 at 8:49 AM
