1994 Ford Probe Grayish or white smoke on during cold start
180,000 MILES • 4 CYL • 2WD • MANUAL
TRIPLESHOTMOCHA
I have a 1994 Ford Probe with a 2.0 liter motor. After the vehicle sits it smokes during a cold start up but then goes away after it warms up. I can't tell if the smoke is gray or white. I have replaced the head gasket, checked and changed the oil and verified coolant color and/or any coolant loss. Everything appears to be normal. What could it be and what may be a remedy to alleviate this issue?
Sep 28, 2010 at 9:27 PM
  • 75,988 POSTS
If its not condensation and smokes at start-up and disappears after the engine is fully warmed-up sounds like valve seals/guides/stems problems-
Sep 28, 2010 at 10:07 PM
