1994 Ford Probe door panel
160,000 MILES • 4 CYL • 2WD • MANUAL
SLAVO1967
how do i remove the manual window crank so i can remove the front door panel? i'm wanting to replace the speaker.
Jun 14, 2008 at 10:11 AM
BLACKOP555
  • 10,386 POSTS
either the skin of the crank pops up and pivots so you can remove hte torx bit on it. or there is a special tool used to remove the clips holding it in.
Jun 14, 2008 at 10:21 AM
