how do i remove the manual window crank so i can remove the front door panel? i'm wanting to replace the speaker.
Jun 14, 2008 at 10:11 AM
BLACKOP555
✓Experienced Mechanic
either the skin of the crank pops up and pivots so you can remove hte torx bit on it. or there is a special tool used to remove the clips holding it in.
