1994 Ford Probe clutch
11,000 MILES • 4 CYL • 2WD • MANUAL
RLA1112
Good evening I am having problems with my clutch. I just had it replaced a year and half ago and the problem is that I have to use my toes to lift the clutch pedal so that I can shift. can you help me with what this problem could be. thank you
RLA
Sep 16, 2009 at 1:48 PM
  • 31,937 POSTS
Hi there,
You may have a leak at the slave or master cylinder, check the fluid level and if low, have the cylinders inspected.
mark (mhpautos)
Sep 16, 2009 at 2:21 PM
