1994 Ford Probe
SERGUIOC
  • 1994 FORD PROBE
Transmission problem
1994 Ford Probe 6 cyl Front Wheel Drive Manual
what needs to be replaced when my clutch pedal stays on the floor when I press down on it and it wont let me shift into gear?
Thursday, December 11th, 2008 AT 4:19 PM
  • 31,937 POSTS
Hi there,
If this is a hydraulic system then you will have a leak at either the slave cylinder at the gear box or the master cylinder on the fire wall (where the fluid goes) this will have to be repaired and the system bleed of air. If a cable the cable has failed, get this inspected by a mechanic.
Mark (mhpautos)
Thursday, December 11th, 2008 AT 4:22 PM
