1993 Ford Probe ROUGH idle when stopped
168,626 MILES • 4 CYL • FWD • AUTOMATIC
JNM25
i have a '93 probe and it has two main problems. 1).whenever i come to a stop at a light or stop sign, the engine idles REALLY rough for about 3 seconds. it will then idle back down for a couple seconds and do the same thing again. happens 100% of the time. feels like my car is rattling to pieces.
2). i put a brand spankin' new battery in and it quickly loses charge. the battery was totally dead after 3 days of no use. what the heck is draining the the juice so quickly?
NOTE: about 3 or 4 years ago my grandfather had the whole car looked over and rebuilt/tuned/fixed. new motor mounts, timing belt, alternator, the works. thank you for taking the time to examine my questions, i appreciate it.
Jan 8, 2010 at 4:42 AM
  • 75,988 POSTS
P1 Clean out the idle air control valve/mtr/ISC and test the throttle position and mass airflow sensors to include a vacuum leak check P2 There's a short circuit within the electrical system draining the battery overnite-Battery drain test below
https://images.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_170.jpg
Jan 8, 2010 at 5:57 AM
