1993 Ford Probe distributor
181,000 MILES • 4 CYL • FWD • AUTOMATIC
CARRNIVORES
the car runs good for about 10 minutes then it dies for 10 or 15 minutes it will start back and run for 10 are 15 more minutes then dies again i replaced the distributor and it runs good for a month are two then does it again.the coil and ignition coil built in the distributor.
Mar 2, 2008 at 6:43 AM
  • 75,988 POSTS
Might want to check whether you have a crankshaft position sensor
Mar 2, 2008 at 7:43 AM
