I have a 1993 Ford Probe 2.0litre automatic.
It has been very well maintained. Recently it will stall out for no reason when driving..like it loses spark or something.
It also now will eventually stall while idling after about 10 minutes or so.
The distributor assembly was just changed about 7months ago.
It has a new fuel pump, spark plugs are good, new spark plug wires, cap and rotor look good.
The IAC valve was cleaned out and made a huge difference in power. MAF sensor was checked and i tried to clean it carefully as well. Fuel filter was recently changed.
I have also checked for any vaccuum leaks but all hoses seem to be excellent.
If this CEL gives me a code 02(Crankshaft position sensor) How can this be fixed? Would it cause these symptoms?
Please let me know as this car has alot of life left in it and has been well maintained.
Thanks guys..it means alot!
Jun 2, 2009 at 1:46 PM
