1993 Ford Probe Clutch Grinds
1993 FORD PROBE
140,000 MILES • 6 CYL • FWD • MANUAL
JARRENCASSTEVENS93
The car starts and runs fine. But it will not go into gear. Whenever i try to put it into gear even reverse it starts grinding. What would be causing this? PLEASE HeLP
May 22, 2008 at 7:54 AM
MIKE H R
  • 3,094 POSTS
strt by checking the fluid in the hydrolic clutch and make sure it is full. Then check the clutch slave cylinder.
May 22, 2008 at 8:36 AM
