1993 Ford Probe Clutch
19,700 MILES • 4 CYL • FWD • MANUAL
TERRY WALTER
There is no clutch pressure. Thre is no pedal on the clutch . It goes to the floor. How do i bleed the air out of clutch.
Jan 27, 2009 at 11:48 AM
DAVE H
  • 13,383 POSTS
if there is no pedal at all ... then it must have a leak somewhere ? check master and slave cylinders plus all brake lines for leaks .. ?
Jan 27, 2009 at 12:22 PM
ETXLADY
  • 9 POSTS
Hey you guys, is there anyway to adjust the clutch on a 1993 2.5 6 cylinder?
Feb 19, 2009 at 11:22 AM
DAVE H
  • 13,383 POSTS
ADJUSTMENTS
SELF-ADJUSTING CLUTCH
On cable controlled models, clutch cable is adjusted automatically by a self-adjusting mechanism attached to clutch pedal. On hydraulically controlled clutch systems, clutch pedal is automatically adjusted and requires no adjustment.
Feb 19, 2009 at 11:39 AM
ETXLADY
  • 9 POSTS
How do I know which on it is. I have a 2.5 6 Cylinder GT.
Feb 19, 2009 at 11:47 AM
DAVE H
  • 13,383 POSTS
It does not matter which system you have fitted .. both are NOT adjustable !!
Feb 19, 2009 at 12:50 PM
DAVE H
  • 13,383 POSTS
you have the hydraulic clutch on your vehicle
Feb 19, 2009 at 1:13 PM
