1993 Ford Probe
ELMO27
1993 Ford Probe Manual
When I start my car it idles at 1,000 RPM and when it trys to go past 2,000 RPMs it jolts until the check engie light comes on the it runs like nothing is wrong. I was wondering if it could be the Crankshaft Position Sensor or the Canister Purge Solenoid. I wanted to know which one would cause it to jolt or if it would be both of them going bad.
Mar 28, 2010 at 5:22 AM
  • 110,248 POSTS
If the check engine light came on, there should be a trouble code stored in the computer. Have you had iut checked? Most nationally recognized parts stores will do it for free.
May 11, 2010 at 3:10 AM
