1993 Ford Probe
111,000 MILES • 6 CYL • FWD • AUTOMATIC
GARY STONEHAM
vehical started and ran fine. Changed transmission now i am unable to get vehical to start i have fuel but am not getting spark i have checked fuses and wiring connections my question is there somethingon the fly wheel a strip of metal or something that would cause the car not to spark i was told this could cause this to accure
Jul 3, 2009 at 9:21 AM
  • 75,988 POSTS
The engine is cranking over if there's a problem with the flywheel or the starter she will not crank over.
No spark
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, cap and rotor,ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jul 3, 2009 at 9:46 AM
