1993 Ford Probe
TSTEVESON1
Engine Mechanical problem
1993 Ford Probe Front Wheel Drive Manual 224,00 miles
I JUST PUT A NEW ENGINE IN THIS CAR AND A NEW PRESURE PLATE AND CLUTH, IT RAN GOOD FOR ABOUT ONE WK. NOW IT WILL NOT START IT WILL NOT EVEN TURN OVER, I CAN PUSH IT POP CLUTH AND IT RUNS FINE, BUT IT WILL NOT START USING THE KEY DOES THIS HAVE SOMETHING TO DO WITH THE NEW CLUTH BECAUSE THE CLUTH ENGAGES THE STARTER, DOES IT NEED TO BE ADJUSTED AND HOW DO I DO THAT?
Feb 24, 2009 at 2:26 AM
DAVE H
  • 13,383 POSTS
check the starter motor wiring .. is not corroded or loose ..
Feb 24, 2009 at 2:58 AM
