1991 Ford Probe keep losin beak fluid quick
JONMONSON
Brakes problem
1991 Ford Probe 6 cyl Front Wheel Drive Automatic
keep losin break fluid quick could it be the break fluid line or something else?
Dec 29, 2008 at 9:46 AM
  • 31,937 POSTS
Hi there,
You will have to check the master cylinder, all the steel lines the flexible lines and the front & rear brakes as well, this leak should be very visible, if in doubt get a qualified mechanic to inspect it for you.
mark (mhpautos)
Dec 29, 2008 at 9:50 AM
